Pressuretrol Pigtail re-install
msmor23
msmor23 Member Posts: 14
Removed to clean it as it was clogged (everything I read said to just buy a new one but only local supply was fresh out).
Anyway, when reattaching Pressuretrol and pigtail- anything special needed? I need to add a little water to pigtail after reinstalling but before attaching Pressuretrol. But do I need to re-calibrate?
Thanks
Mike
  • B_Sloane
    B_Sloane Member Posts: 56
    no, and the old one was fine
    soak it in vinegar for a bit next summer
    msmor23
  • JUGHNE
    JUGHNE Member Posts: 11,408
    B_Sloane, you mean soak the pigtail, not the pressure control?
    msmor23
  • B_Sloane
    :D
  • msmor23
    Thanks everyone. This forum is a huge help
  • Fred
    Fred Member Posts: 8,542
    Yes, The pigtail. If it is a steel one, put a brass one on before next season. They don't clog as quickly and clean a lot easier.
