3-D Printing Hoffman #7 Steam Radiator Valve Handles
HeatingHelp
HeatingHelp Administrator Posts: 706
edited January 2020 in THE MAIN WALL
Hoffman has not made this steam radiator valve since the 1930s. 3-D printing is used to create this otherwise obsolete part.
Read the full story here
GordoPC7060IronmanSlowYourRoll
  • Controlsgirl
    Controlsgirl Member Posts: 13
    Why did they stop making this valve?
  • Grallert
    Grallert Member Posts: 969
    The market for these valve is now only the service market. There was a time these were being installed on a regular basis across the country. Those days are gone along with most of the companies that made the equipment. unfortunate for the folks taking care of these systems.
  • Controlsgirl
    I have them on all of my radiators in my home and none of the radiators have steam traps. The boiler guy wants to rip them all out, use normal valves and add steam traps...
  • KC_Jones
    KC_Jones Member Posts: 5,884
    What is his reasoning? Are they broken?
    2014 Weil Mclain EG-40
  • Gordo
    Gordo Member Posts: 857
    edited January 2020
    @Controlsgirl : In general, the Hoffman #7 valve can be successfully rebuilt to full functionality (I humbly direct your kind attention to my videos on the topic). If they are properly adjusted, and with a Vaporstat on your boiler, you theoretically do not need steam traps.
    PC7060
  • Controlsgirl
    @KC_Jones a mix of issues. New boulder installed. 3 of the 4 radiators upstairs werent working bc I messed them up. New boiler...that and there are no traps. Thank god for the YouTube videos. 2 of the three radiators are now working and the 3rd one should be working tonight.
  • gerry gill
    gerry gill Member Posts: 3,078
    Very cool indeed Gordo!!
    gwgillplumbingandheating.com
    PC7060Gordo
  • Controlsgirl
    I loved his videos on these! I was able to restore 10 valves of mine that were stuck and inoperable. And now I use them all of the time. I am still missing about 6 handles though! I need to make sure I have a rag or oven mitt without the handle. They get hott!
    Gordo
  • garfieldsimons
    garfieldsimons Member Posts: 14
    They make a wax for casting that can be printed. No need to design a mold.
  • Gordo
    @Controlsgirl : Please PM me.
    I should be able to have handles for you.
  • PEvans
    PEvans Member Posts: 142
    @Gordo what about other valve handles? I have the ones pictured below all over my house and I'm missing probably 2-3 handles. I don't know the manufacturer (maybe Watts?). Even though these are probably common valves, I have not found replacement handles anywhere!
  • fentonc
    fentonc Member Posts: 305
    Odd brackets and handles really are where home 3D printing shines - I've made all kinds of random house widgets with mine (including a steam radiator valve handle at my previous house)
    Gordo
  • Gordo
    @PEvans: Replacement radiator handles for the valves in your pictures are more or less available as after-market kits.
    They are generally made of phenolic resin with a stamped metal insert of various sizes to accommodate different size square stems.
  • SlowYourRoll
    SlowYourRoll Member Posts: 187
    great work Gordo
