S
JPL941
JPL941 Member Posts: 51
edited August 2023 in Radiant Heating
Hello
    EBEBRATT-Ed Member Posts: 20,177
    Just wire the pumps to run at the same time.
    I would say inhibitor, an expansion tank, air scoop and vent, a prv for water feed and a relief valve would be needed. I would also suggest a filter or mag separator depending on the condition of the system. I would think you could use a bronze pump
    Others that know more about water quality than me will chime in.
