S
JPL941
Member Posts: 51
Hello
Just wire the pumps to run at the same time.
I would say inhibitor, an expansion tank, air scoop and vent, a prv for water feed and a relief valve would be needed. I would also suggest a filter or mag separator depending on the condition of the system. I would think you could use a bronze pump
Others that know more about water quality than me will chime in.0
