Radiator vents open and close repeatedly
Lately my radiator vents are opening and closing repeatedly, especially during the initial part of a cycle. The open and close times are around a minute or so. The vents hiss fairly loudly when open and make a noticeable sound when they close. The vents were replaced a few months ago. The radiators are single-pipe. Anyone know what could cause this and whether it means something is amiss?
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,577
    What make of radiator, and main vents are on the system?
    What is the pressure of the system?—NBC
  • dopey27177
    dopey27177 Member Posts: 916
    Your steam pressure may be set to high.
    Your boiler pressure should be no more than 3 PSIG with a 1 pound drop back.
    Jake
  • jimb245
    jimb245 Member Posts: 6
    The embossing on the radiators is American Radiator. The main vents are Dole Valve No 3C - they probably havent been serviced for a long time. The pressure gauge on the boiler always reads zero so guess it's not functional. The cut-in pressure setting on the pressuretrol seems to be at the lowest point (picture attached) and the cut-out wheel shows a "1" when viewed from the opening of the box.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    I think a 3C is for convectors, like a Hoffman 71C. That's pretty small for a main vent.
  • jimb245
    Thanks. Guess I need to get the vents and pressure checked.
