Dealing with mercury in an old heating system
HeatingHelp
HeatingHelp Administrator Posts: 638
edited December 2019 in THE MAIN WALL
If you're staring at an odd, old device and you don't know what it is, put your hands in your pockets and back away from the thing.
Read the full story here
  • Rocky_3
    Rocky_3 Member Posts: 232
    Now I know why a lot of people put their hands in their pockets and slowly walk away from me when I try to start a conversation with them! Mystery solved! Thanks, Dan!
    Solid_Fuel_ManIntplm.mattmia2
  • Controlsgirl
    Controlsgirl Member Posts: 13
    Great article. Fun read.
    mattmia2 Member Posts: 9,672
    I know someone that has the remains of one of these systems in Detroit.
  • Pumpguy
    Pumpguy Member Posts: 659
    The most common place I see Mercury is in old Mercoid vacuum switches. Where still installed they are working flawlessly. Not only totally reliable, but super easy to adjust; just set the pointers to the off and on settings and you're done.
    On the other hand, the 9016 diaphragm type usually found on today's vacuum pumps have to be set on a change-and-try basis. This isn't so bad where there's only one switch, but on a duplex unit, you have 2 switches. Both need to be set to turn off at the same point, but the primary switch needs it's on point to be set just a little higher than the secondary switch. I find this to be an aggravating task.
    Also, I have found that over time, these switches go out of adjustment and need a repeat of this aggravating task.
    At last check, these Mercoid vacuum switches were still available, although frowned upon for reasons described, and now getting prohibitively expensive.
    Does anyone know of other vacuum switches that have the reliability and ease of setting as the old Mercoids? Those sold by the same company are available Mercury free with snap action mechanisms, but their minimum differential is too great for use in this application.
    I've got to think there is an electronic switch out there somewhere.
  • Pumpguy
    Yeah, me too. Problem is all my searches have come up either empty or not suitable. Switch needs to be wide range adjustable, and able to complete two (2) separate control circuits.
    I'm hoping someone here has some suggestions.
    That stuff was so fun to play with. I had a gold ring that I coated with mercury. A couple of days later, it disintegrated.
    A liquid metal!
    ethicalpaul Member Posts: 5,704
    My mom, a nurse, brought me some to play with from a broken thermometer. That doesn't happen anymore!
    NJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el
