Looking for a radiant heat thermostat with a remote AIR temperature sensor
remount
Member Posts: 1
Air sensor--not slab. Thanks.
This should do the trick.
http://www.tekmarcontrols.com/products/zoning/552.html"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0
