Smoke pipe question. Seam up or down?
old wrench
Member Posts: 14
Talking to someone today about smoke pipe/ vent connector. When I was a young lad years ago we always put the smoke pipe seam down (maybe because grandpa did). Looked in the IRC and Fuel gas code but no mention of it anywhere. I would love to find a link from a manufacturer with anything on this.
As far as I know, male facing the direction the exhaust is going. So the appliance would be male and chimney female.
Wood stoves are the opposite to keep condensation and creosote from running out of the pipe.
Unless you mean the locking seam on the side of the pipe? I don't think anyone cares about that one.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I usually put the seam down but don't think it matters.
I used to find a lot of flue pipe with few screws and poorley secured. One of my fears was a smoke pipe falling down or becoming disconnected. No protection against that (except for smoke detectors)
I usually put at least 3 screws in every joint and on larger sizes I shoot a few screws right through the Pittsburgh lock on the seam0 -
We put 3 screws in each joint and reinforce our smoke pipe installs with sheet metal drive cleats......2
Drive cleats make great hangers & straps......0
What's smoke pipe, never heard of it (jk). I've heard of flue pipe.
Terms like 'smoke pipe', jet line, blast tube, soot saw, soot vacuum, give the impression of a heating system that's dirty, and loud, and needs constant cleaning.
They are kindler, gentler (cleaner, quieter) oil burners now...
@MikeL_2 as far as the drive cleats, I do like the one at the chimney base, but the others look like both overkill and like you're trying to prevent an explosion from blowing off the flue pipe. Does that happen often in your area? I do like the nice bead of sealant over a foil tape mess at the damper.
Of course 3 properly placed screws (code) in each joint.
As far as seam, usually up except for the piece with the draft regulator, then that seam is opposite the center of the regulator.There was an error rendering this rich post.
To me, if two seams are next to each other, it leaves too large a gap. I stagger the seams. And why do I need to re crimp a factory crimp?0
I’m ocd so when we do pipe flue pipe the seems and screws have to match up and seams are always faced down or towards the wall.0
Hi, I decided to look it up: Definition of smoke pipe : a usually thin metal pipe connecting a possible source of smoke to a chimney or smokestack. Seems pretty all inclusive
As I deal with non-condensing gas mostly, I'm in the habit of facing the seam up. This prevents the condensate that forms on startup from dripping out the seam. I don't think I've ever seen anything in code about how it should be.
Yours, Larry1 -
Steveusa,
I consider myself lucky to have apprenticed ( starting in the late 60's ) in a shop that did plumbing, hvac, hydronic heating, and sheet metal fabrication. Along with a variety of trade skills, I absorbed the local lingo.
Wholesaler counter reps, manufacturers reps, salesmen & women, journeymen, related trades people, and all others I came in contact with knew what smoke pipe was; at that time there was never any confusion, or a proposal for a name change.
As far as overkill & explosions; it takes an extra 15 minutes or so to beef up an install with a back strap. Keeping adjustable fittings aligned, level, and plumb, and, added protection from a bump or bruise is my goal. Explosions are not common here and I'm certain my installs are not explosion proof. My fastening method does help prevent adjustable elbow rolled seam failure..........1
