Pure Pro Advantage Review
djc1972
djc1972 Member Posts: 1
I just received a quote for a Pure Pro Advantage 3 Chamber OIl Boiler. I cannot seem to find any reviews of this boiler or comparisons to and Weil Mclaine, Burnham or Buderas, Can anyone help? Thanks!
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,608
    It's a rebranded Crown made by US Boilers. Online reviews of boilers are almost useless, they're really reviewing the installer in most cases.
    Steamhead Member Posts: 18,877
    If you're going to get a PurePro, get the Trio- it's a 3-pass boiler which is more efficient and much easier to maintain.
    Semi-retired
    kcoppRobert O'Brien
  • Jellis
    Jellis Member Posts: 232
    I assume they offered the Advantage vs the Trio to provide a hot water coil?
    I would recommend the Pure pro Trio with a indirect hot water storage tank. The trio is more serviceable than the advantage and the hot water tank vs the coil will ensure longer more efficient run times.
    This assuming you have the space for a storage tank that is.
  • STEVEusaPA
    I'd probably get a quote for an energy kinetics boiler.
    JellisSuperTech
