Pure Pro Advantage Review
djc1972
Member Posts: 1
in Oil Heating
I just received a quote for a Pure Pro Advantage 3 Chamber OIl Boiler. I cannot seem to find any reviews of this boiler or comparisons to and Weil Mclaine, Burnham or Buderas, Can anyone help? Thanks!
It's a rebranded Crown made by US Boilers. Online reviews of boilers are almost useless, they're really reviewing the installer in most cases.0
If you're going to get a PurePro, get the Trio- it's a 3-pass boiler which is more efficient and much easier to maintain.
Consulting2 -
I assume they offered the Advantage vs the Trio to provide a hot water coil?
I would recommend the Pure pro Trio with a indirect hot water storage tank. The trio is more serviceable than the advantage and the hot water tank vs the coil will ensure longer more efficient run times.
This assuming you have the space for a storage tank that is.
- 125 Chimneys & Flues
