Heat Exchanger
Are plate coolers used for cooling liquids such as milk on farming operations the same as a heat exchanger, or is there some sort of difference? It appears to be the same principal, but just out of curiosity is there something that separates the two?
    hot_rod Member Posts: 27,323
    about the same, it could be a different grade of stainless for food products?
  • Jolly Bodger
    Jolly Bodger Member Posts: 209
    food product probably (should be) double walled.
