Leaking copper tube...custom or off the shelf part?
JSladky
Member Posts: 1
Hi everyone and Happy almost new year!
First post on this site but have been a long time reader...between this site and the "Lost art of steam heating" book I have managed to replace/upgrade/tweak a ton of stuff on our steam heat setup.
"Recently" I sprung a leak on a small copper pipe on the boiler itself. The pipe runs from low water cutoff to the pipe that runs from the top tube of the sight glass. I attached a picture but cant seem to find what this part would be called or if it is even an off the shelf part at all.
Boiler is a Crown JBF52EID
Any help would be appreciated!
Thanks,
Joe
Thanks,
Joe
I'm sure there's a special name for it... but there's no good reason you can't make your own. Soft copper tubing of the right size, looks like compression fittings but you can double check that. I'd use a tube bender, though, to bend it because the stuff is so easy to kink.Br. Jamie, osb
We typically rip that soft tubing and compression fitting out and just replace it with 3/8” brass fittings and nipples.0
that tube is made of brass and is called l vent on a mc donnel-miller low water cut off.Can be brought at a Plumbing supply that has heating supplies,boilers, heating controls,etc.0
The McDonnell & Miller part is rather cheesy. I don't think it's real brass. @EzzyT 's idea is good, as is @Gordo 's which will also work on a #67:
https://forum.heatinghelp.com/discussion/178342/removing-a-failed-mcdonnell-miller-47-2-and-installing-a-hydrolevel-711c-manifold-and-lwco
We prefer the Hydrolevel setup since it has no moving parts.All Steamed Up, Inc.
Consulting0 -
@JSladky
That tubing is part of the McDonnell Miller low water cut off kit. I don't know if its available as a separate part.
It is 1/2" OD tubing. I would find a piece of 1/2" od tubing (hard or soft) cut the old tubing out and replace it with new. Save the fittings .
You need: 1/2" od tubing
1 1/2" od sweat or compression 90 degree elbow (if you don't have a tubing bender)
2 1/2" od compression sleeves0
