Steam Service Recommendations for CT?
caseycamire
Member Posts: 20
Hello all - I'm looking for a good steam technician to go over my steam system. Any recommendations for CT? The site has NY, MA, and RI, so I'm surrounded, but none for CT.
Any leads are appreciated!
@caseycamire where in CT are you located?0
I know that @Charlie from wmass serves Connecticut, and is one of the best out there. He's also rather busy...Br. Jamie, osb
Hey guys! Thanks for the responses. Out of state that serves CT is totally fine. I'm in Wallingford, CT if that makes a difference. About halfway between Hartford and New Haven.0
@Charlie from wmass works out of Springfield, so he's probably the closest. You can find his contact info here: https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heatingJust another DIYer | King of Prussia, PA
Second that.Hap_Hazzard said:@Charlie from wmass works out of Springfield, so he's probably the closest. You can find his contact info here: https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
Consulting1 -
Thanks guys! I'll reach out to Charlie.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
