Water softener
Doester
Member Posts: 17
Hi all, we are installing a water softener in our house and I am wondering if I should use softened water or not in my steam boiler. Our water is really hard (13 grains). I think the previous owners had softener but took it with them. My system doesn’t lose water, but I do blow it down weekly. Thanks!!
Thanks Jamie!!!0
more reading on the topic of hard water. Having the water analyzed would also be a good step.
https://www.hpac.com/heating/article/20927359/how-to-prevent-steamboiler-failureBob "hot rod" Rohr
Living the hydronic dream1 -
Good advice. Until you know what you're dealing with, you can't tell what kind of remediation, if any, would be appropriate. But it goes without saying that your standard household ion-exchange water softener would never be appropriate. Microfiltration might be.Just another DIYer | King of Prussia, PA
Lots of opinions on Ion exchange water for steam boilers.
I suspect type of boiler, hardness of the water, how much water is added, and other factors need to be looked at.
https://www.miuraboiler.com/how-are-water-softeners-used-in-steam-boilers/
Living the hydronic dream0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
