Creaking pipe support
See picture. The thing holding the pipe to the basement ceiling creaks loudly. What do I do?
The quick and dirty solution would be to try to slip a piece of rubber or heater hose or something of that sort between the pipe and the hanger iron.0
I don't really have any pieces of rubber. Would an elastic work?0
Replace it with a pipe hanger. Perf strap isn't rated for black pipe. I know you see a lot of it used for that, but it's not safe.Just another DIYer | King of Prussia, PA
Something like this to replace the band iron.
Check the type of pipe, and your sizes. Both for pipe diameter and total length of hanger for proper fit.
Use a hanger that is meant for black iron pipe that you have in your post.0 -
Cut a 2" x 4" x 8' piece of lumber to prop-up under the pipe (snugly) before you loosen the pipe-strap screws. Then change to a real pipe hanger.0
Am I seeing things or do you have to take the pipe apart to use that hanger?Intplm. said:
Use a hanger that is meant for black iron pipe that you have in your post.Just another DIYer | King of Prussia, PA
Where can you buy that hanger?0
I found it here: http://www.vegaindustrialsupply.com/our_products/hangers_and_support_hardwareAMW said:Where can you buy that hanger?
and here: https://www.supplyhouse.com/Swivel-Rings-13650000Just another DIYer | King of Prussia, PA
I am not suggesting your current pipe hanger is right or wrong. However, I would look for some framing that the pipe might be rubbing against. Oftentimes, steel hangers and steel pipe expand at about the same rate. However, wood joists and studs expand at a much different rate. Most noises that we witness are inside the pipe (water hammer, velocity, air in pipes, etc) or from a pipe rubbing against a wooden joist.0
I've heard a lot of people here say that a piece of a plastic milk jug is the perfect spacer between the pipe and the hanger to offer some glide. I've used pieces of soda bottle.mattmia2 said:The quick and dirty solution would be to try to slip a piece of rubber or heater hose or something of that sort between the pipe and the hanger iron.
New owner of a 1920s home with steam heat north of Boston.
Just trying to learn what I can do myself and what I just shouldn't touch0 -
By the way, these are probably the most popular hangers for black pipe: https://www.supplyhouse.com/Bluefin-BLCH200-2-Black-Clevis-Hanger
You just get a bunch of these in the appropriate sizes, some brackets (there are different types for different surfaces) some 3/8" ready-rod and a big bag of 3/8" nuts and go hang pipe.Just another DIYer | King of Prussia, PA
Would those reduce the creaking? There doesn't seem to be any rubber on them, or any way they could have more give than the current hangers that I have.0 -
They can swivel a little at the clevis joint, not that I've ever noticed mine moving all that much. If your pipes are moving a lot, it might be time to skim your boiler. Does the water level in the gauge glass move up and down when the boiler is making steam?Just another DIYer | King of Prussia, PA
They will reduce the creaking over what you have in the picture, if creaking where it goes thru wood small strips from a plastic milk bottle help.AMW said:> By the way, these are probably the most popular hangers for black pipe
not sure if its been mentioned, but I'm intrigued by these hangers with a roller for the pipe to roll over as it expands. never used them, and I'm sure they are overkill for the minimal amount of expansion that one sees in a residential main, but I like the design, myself.
https://www.grainger.com/product/4LRE2?gclid=CjwKCAiAob3vBRAUEiwAIbs5TsFgrwbrlCXlVJ3MKjkuXUdmWf0MGjJzzXO7UO0RYOFHltQCtaJIVxoCSecQAvD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=CjwKCAiAob3vBRAUEiwAIbs5TsFgrwbrlCXlVJ3MKjkuXUdmWf0MGjJzzXO7UO0RYOFHltQCtaJIVxoCSecQAvD_BwE:G:s&s_kwcid=AL!2966!3!50916758277!!!g!82128325077!?cm_mmc=PPC:+Google+PLA?campaignid=175663197
If your pipes are moving enough to need that, something's wrong.
Consider that the take-offs are rigidly connected to the main, and the 45° elbows often rest on the foundation sill, what's going to happen to the sill and/or the runout over time if the main is moving excessively back and forth?
If you're seeing a lot of movement, or hearing a lot of rumbling and creaking whenever your boiler is steaming, you need to skim it.Just another DIYer | King of Prussia, PA
8 or 10" is the smallest I've seen in that style. A little overkill!Zipper13 said:not sure if its been mentioned, but I'm intrigued by these hangers with a roller for the pipe to roll over as it expands. never used them, and I'm sure they are overkill for the minimal amount of expansion that one sees in a residential main, but I like the design, myself.
https://www.grainger.com/product/4LRE2?gclid=CjwKCAiAob3vBRAUEiwAIbs5TsFgrwbrlCXlVJ3MKjkuXUdmWf0MGjJzzXO7UO0RYOFHltQCtaJIVxoCSecQAvD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=CjwKCAiAob3vBRAUEiwAIbs5TsFgrwbrlCXlVJ3MKjkuXUdmWf0MGjJzzXO7UO0RYOFHltQCtaJIVxoCSecQAvD_BwE:G:s&s_kwcid=AL!2966!3!50916758277!!!g!82128325077!?cm_mmc=PPC:+Google+PLA?campaignid=1756631970 -
We've used the roller type clevis hangers on larger jobs with four, five, six, eight and ten inch steel mains. They work wonderful, but are not cheap by any means.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
