Creaking pipe support
AMW
AMW Member Posts: 9
See picture. The thing holding the pipe to the basement ceiling creaks loudly. What do I do?
    mattmia2 Member Posts: 13,811
    The quick and dirty solution would be to try to slip a piece of rubber or heater hose or something of that sort between the pipe and the hanger iron.
  • AMW
    AMW Member Posts: 9
    I don't really have any pieces of rubber. Would an elastic work?
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Replace it with a pipe hanger. Perf strap isn't rated for black pipe. I know you see a lot of it used for that, but it's not safe.
  • Intplm.
    Intplm. Member Posts: 2,703
    Something like this to replace the band iron.
    Check the type of pipe, and your sizes. Both for pipe diameter and total length of hanger for proper fit.
    Use a hanger that is meant for black iron pipe that you have in your post.
  • psb75
    psb75 Member Posts: 1,055
    Cut a 2" x 4" x 8' piece of lumber to prop-up under the pipe (snugly) before you loosen the pipe-strap screws. Then change to a real pipe hanger.
  • Hap_Hazzard
    Am I seeing things or do you have to take the pipe apart to use that hanger?
  • Wellness
    Wellness Member Posts: 154
    edited December 2019
    @Hap_Hazzard. Hanger separates at top bushing to install around pipe.
    Hap_HazzardIntplm.
  • AMW
    AMW Member Posts: 9
    Where can you buy that hanger?
  • Hap_Hazzard
  • Intplm.
    @AMW Any local reputable plumbing supply house should have this. Maybe it can be found at a hardware store too. Sometimes the local older private hardware stores will stock both of these items.
  • ScottSecor
    ScottSecor Member Posts: 998
    I am not suggesting your current pipe hanger is right or wrong. However, I would look for some framing that the pipe might be rubbing against. Oftentimes, steel hangers and steel pipe expand at about the same rate. However, wood joists and studs expand at a much different rate. Most noises that we witness are inside the pipe (water hammer, velocity, air in pipes, etc) or from a pipe rubbing against a wooden joist.
  • Zipper13
    Zipper13 Member Posts: 229
    I've heard a lot of people here say that a piece of a plastic milk jug is the perfect spacer between the pipe and the hanger to offer some glide. I've used pieces of soda bottle.
    New owner of a 1920s home with steam heat north of Boston.
    Just trying to learn what I can do myself and what I just shouldn't touch
  • Hap_Hazzard
    By the way, these are probably the most popular hangers for black pipe: https://www.supplyhouse.com/Bluefin-BLCH200-2-Black-Clevis-Hanger
    You just get a bunch of these in the appropriate sizes, some brackets (there are different types for different surfaces) some 3/8" ready-rod and a big bag of 3/8" nuts and go hang pipe.
  • AMW
    AMW Member Posts: 9
    Would those reduce the creaking? There doesn't seem to be any rubber on them, or any way they could have more give than the current hangers that I have.
  • Hap_Hazzard
    They can swivel a little at the clevis joint, not that I've ever noticed mine moving all that much. If your pipes are moving a lot, it might be time to skim your boiler. Does the water level in the gauge glass move up and down when the boiler is making steam?
    pecmsg Member Posts: 6,381
    They will reduce the creaking over what you have in the picture, if creaking where it goes thru wood small strips from a plastic milk bottle help.
  • Zipper13
    not sure if its been mentioned, but I'm intrigued by these hangers with a roller for the pipe to roll over as it expands. never used them, and I'm sure they are overkill for the minimal amount of expansion that one sees in a residential main, but I like the design, myself.
    https://www.grainger.com/product/4LRE2?gclid=CjwKCAiAob3vBRAUEiwAIbs5TsFgrwbrlCXlVJ3MKjkuXUdmWf0MGjJzzXO7UO0RYOFHltQCtaJIVxoCSecQAvD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=CjwKCAiAob3vBRAUEiwAIbs5TsFgrwbrlCXlVJ3MKjkuXUdmWf0MGjJzzXO7UO0RYOFHltQCtaJIVxoCSecQAvD_BwE:G:s&s_kwcid=AL!2966!3!50916758277!!!g!82128325077!?cm_mmc=PPC:+Google+PLA?campaignid=175663197
  • Hap_Hazzard
    If your pipes are moving enough to need that, something's wrong.
    Consider that the take-offs are rigidly connected to the main, and the 45° elbows often rest on the foundation sill, what's going to happen to the sill and/or the runout over time if the main is moving excessively back and forth?
    If you're seeing a lot of movement, or hearing a lot of rumbling and creaking whenever your boiler is steaming, you need to skim it.
    8 or 10" is the smallest I've seen in that style. A little overkill!
  • ScottSecor
    We've used the roller type clevis hangers on larger jobs with four, five, six, eight and ten inch steel mains. They work wonderful, but are not cheap by any means.
