F/T Trap at bottom of steam line.
foxbrother
Member Posts: 2
At the bottom of a main steam line where it goes vertical to split on a two pipe system I have a fairly large trap maybe 6" tall. It appears that it is stuck open based on temps its feeding back to condensate return line my questions is for a 4" mainline on a low pressure system should that big of a trap be there ?
Depends on how much condensate you are processing. I can't imagine you'd need anything more than a 1" NPT trap, but those are typically 6" tall, not what I consider a big trap. Post a pic.Peter Owens
SteamIQ0 -
Will do when im back on site didnt have one on my phone. Thank you
- 116 Geothermal
- 15.8K Strictly Steam
- 52 Industry Classes
