Valve replacements, did I get a bad one?
bdwild
Member Posts: 25
I plan to replace three that are leaking - two are 1" and one is 1 1/4". As I hope you can see in the photos (all handles are turned to full open), the two 1" valves open all the way to where the inner plate seats at top of bonnet.
The 1 1/4 does not. It's at least a 1/4" if not 3/8 away from seating.
Is this "fully open"? Did I get a faulty valve?
I agree with Fred, it seems fine. It may be that the little 1” valves have to be made to open more to provide enough space for steam and condensate flow
@Fred and @ethicalpaul , thank you! Good to know before the install adventure begins.0
