Check valve question.
JackW
JackW Member Posts: 236
The circulators I bought for my radiant heat redo have check valves in them. The flow of all three circulators is down (outlet on the bottom) is there any reason to keep the check valves in the circulators?
Thanks.
  • DZoro
    DZoro Member Posts: 1,048
    Yes keep them in.
    It's helpful to others if you keep all your information on one post so everyone else can follow your project
    STEVEusaPA
  • JackW
    @DZoro I don't understand what you mean by keeping all my info on one post. If I have a different subject matter don't I need a new thread?
    Thanks for the answering my question.
  • Ironman
    Ironman Member Posts: 7,886
    The checks are to prevent flow from one circuit from pushing into the ones that are off.
    Bob Boan
    JackW
  • JackW
    @Ironman. Wasn't sure if that would be a problem or not, thanks. In they will stay.
  • DZoro
    You can ask away, in the same post. It's easier for everyone to follow along with the project. And help you out.
    D
    JackW
  • JackW
    Ah, didn't realize that. Thanks.
