Danfoss valve heads
bigpete638
Member Posts: 80
I’m working on a college campus and there are danfoss valves everywhere missing their hats. They must be older models because all the replacement heads we have are threaded. Is there a website that could point me in the direction of which heads could use on these valves?
Thank you Bill_17!0
We just need to adjust manually. It’s tough getting parts around here. I was told the adaptors were ordered. I doubt it but I’ll just push for new valves if possible. The pins in half the valves don’t move. The t stat guy mentioned those can be replaced as well but after purchasing all material, it might cost same as new valves.0
@JoeEngineer is it safe to use a solvent such as yield or wd40 to assist in freeing them?0
@Bill_17 thanks again. Material is in short supply. The budget doesn’t allow much and I’m working on a campus with 32 buildings. The heating systems in all of them should have been replaced twenty years ago. I’m going to need a lot of help. It’s great to be working on a high pressure plant though. I really appreciate all the information from this site.0
I would replace the worst offenders, or the ones in the president's office. If you can get buy in by showing results you will likely see improvements in your budget to do the rest. Over time as more valves are replaced you should also be able to show improvements in operating efficiency which will help your cause.1
I’m lucky to not have to deal with dorms. None on our campus. I think they have manual danfoss valves. Just an adjustable cap as opposed to a head that looks to be easily damaged.0
https://www.supplyhouse.com/Danfoss-013G8020-3-4-Straight-Thermostatic-Radiator-Valve?gclid=CjwKCAiAzuPuBRAIEiwAkkmOSFuYdAWkVqan8BfUtc15ILDY_rw_6k8J5aFWcYlbj0v140w2fDU8TBoCpnEQAvD_BwE
Think this is it off a supply house website0 -
It appears I forgot to say thank you for all the information. Sorry for the delay.0
- 120 Geothermal
