Tekmar Controls
northernfrontier
Member Posts: 2
Designing a news injection pump system for radiant slab, snow melt and unit heaters using Tekmar Controls Designer series with TN4 net. What do you do when you have more modules that are designed for the left side of their power control boxes, than you have need of the right side modules. Is there an approved method of powering left side modules like 440s when you only need one power module like a 346
You don't have to do it with modules. These stand-alone units may be easier. http://www.tekmarcontrols.com/products/hvac-systems/444.html"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I was hoping that was an option, just could not find any Tekmar design documents that showed mixing designer series units with the standalone performance or classic units. Wanted to stick with TN4 where ever possible. thanks.0
