Nest Wiring to Aquastat
Hopefully this is simple to answer. I tried searching google and this forum, but I didn't get any results.
I have a Repco boiler with a Honeywell Aquastat.
It is a rental and I want to install a Nest E thermostat so I don't have to drive down each time I get a heating complaint.
According to the Honeywell manual, the Tv and T terminals go to the thermostat. It doesn't say necessarily which goes to R and W. Does it matter to Nest E which goes to which?
If I want to add a common wire, do I tap into the W or Z terminals on the Aquastat? I found one webpage alluding to that, but the information on that page didn't seem credible. If someone could confirm, or answer this question, that'll be great.
Thank you.
    HVACNUT Member Posts: 7,201
    edited November 2019
    W-Z is your common.
    TV is your 24v so switch the red and white wires so they correspond to R and W at the thermostat.
    Do you plan on running a new 3 conductor thermostat wire because I only see 2 wires?
    dooododoo
  • dooododoo
    dooododoo Member Posts: 25
    > @HVACNUT said:
    > W-Z is your common.
    Thank you for your help.
    Yes, I’m going to replace the 2 conductor with a 3 conductor wire. Then it’s a matter of connecting it like this, correct?
    Aquastat - wire - Nest
    Tv - red wire - R
    T - white wire - W
    W or Z - blue wire - C
    That's all there is to it. Then the Nest will guide you through the promps.
    Nests also make nice hockey pucks.
    STEVEusaPAdooododoodelta T
