Nest Wiring to Aquastat
dooododoo
Member Posts: 25
Hopefully this is simple to answer. I tried searching google and this forum, but I didn't get any results.
I have a Repco boiler with a Honeywell Aquastat.
It is a rental and I want to install a Nest E thermostat so I don't have to drive down each time I get a heating complaint.
According to the Honeywell manual, the Tv and T terminals go to the thermostat. It doesn't say necessarily which goes to R and W. Does it matter to Nest E which goes to which?
If I want to add a common wire, do I tap into the W or Z terminals on the Aquastat? I found one webpage alluding to that, but the information on that page didn't seem credible. If someone could confirm, or answer this question, that'll be great.
Thank you.
Thank you.
> @HVACNUT said:
> W-Z is your common.
> TV is your 24v so switch the red and white wires so they correspond to R and W at the thermostat.
> Do you plan on running a new 3 conductor thermostat wire because I only see 2 wires?
Thank you for your help.
Yes, I’m going to replace the 2 conductor with a 3 conductor wire. Then it’s a matter of connecting it like this, correct?
Aquastat - wire - Nest
Tv - red wire - R
T - white wire - W
W or Z - blue wire - C0 -
- 125 Chimneys & Flues
