Eureka: An Early Diverter Tee
HeatingHelp
HeatingHelp Administrator Posts: 718
edited November 2019 in THE MAIN WALL
In 1897, Eureka made an early version of what we now call the diverter tee. It worked by creating a drop in pressure along its run, which encouraged the water to flow into the radiator.
Read the full story here
  • onyx
    onyx Member Posts: 6
    I have a diverter t even older than this one. I am switching to pex most of my system is missing, gone, or damaged
    Steamhead Member Posts: 18,205
    The photo shows the name "Ill. Malleable Iron Co, Chicago" on the tee. We've seen this name before- they marketed the "Imico" Vapor system, which appears on pages 9-10 of @DanHolohan 's "The Lost Art of Steam Heating Companion".
    Consulting
  • Hvac_artisan
    Hvac_artisan Member Posts: 21
    I just bought a 130 year old building. It has been a plumbing shop it’s entire life. And we are the 4th owners. The whole system is diverted t,s on the 3 and 4” main. Gravity feed hot water system.
    Pics?
    Where are you located?
    Consulting
    ratiomattmia2
    mattmia2 Member Posts: 15,602
    I guess @Hvac_artisan answered my question. I assumed this had to be gravity. I guess slowly moving water changes pressure through a restriction too...
  • Hvac_artisan
    @Steamhead delavan WI
  • Hvac_artisan
    @Steamhead check out the video tour I posted on YouTube
    https://youtu.be/3TLRHWxdiUE
  • MarkMurf
    MarkMurf Member Posts: 40
    We used to see them fairly frequently in the older buildings of Hudson County , N.J. "Dad , what's that ?" "Ehhh , like a mono-flow tee . Nothin to fix . Nothin to mess with . That's not the problem ."
