What to do with removed 9 ft wall radiator?
I have a 9 ft Pierce Buttler wall radiator that I no longer need. I estimate it at 90 EDR. Does anyone have any suggestions on anything useful/helpful to do with it other than scrap metal? I'd really hate to trash it...
    Steamhead Member Posts: 17,838
    Where are you located?
    Consulting
  • HomerJSmith
    HomerJSmith Member Posts: 2,641
    Put it on Ebay. Joke! You could contact your area wholesale plumbing and heating company and ask if you could put up a note that the tradesmen could see, offering it.
  • mroberts5
    mroberts5 Member Posts: 76
    One hour north of Philadelphia. PA.
  • acwagner
    acwagner Member Posts: 512
    You can try an architectural salvage. Looks like a few in Philadelphia.
    "Wagner Salvage" (no relation) says they specialize in cast iron radiators.
    Burnham IN5PVNI Boiler, Single Pipe with 290 EDR
    18 Ounce per Square Inch Gauge
    Time Delay Relay in Series with Thermostat
    Operating Pressure 0.3-0.5 Ounce per Square Inch
  • mroberts5
    They said they don't buy or trade. I guess they get all their rads for free??
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,360
    President
    HeatingHelp.com
  • acwagner
    Will they take it away for free? That might be the best you can hope for.
    I found, at least in my area, there isn't much of a market for old rads. Especially the very large rads like yours.
  • TAG
    TAG Member Posts: 792
    I'm redoing a church about an hour north of Philadelphia -- I can't use it either. When I was redoing my place in Chestnut Hill years ago ... nice ones were hard to find.
    I would hate to trash it as well ... sounds like the type that was in the utility rooms and garage at my grandparents house on the main line.
    I'm not sure when the big transformation occurred -- so many middle class houses lost radiators ..replaced with fin tube.
  • Canucker
    Canucker Member Posts: 723
    In my area, I am the market. Admittedly, it's not a very large market, like you said.
    I would love a 9 ft wall radiator for my future garage project. Unfortunately, Philly is a little too far away from Canada
    You can have it good, fast or cheap. Pick two
  • The Steam Whisperer
    The Steam Whisperer Member Posts: 1,290
    its sort of funny....here in Chicago, where hot water has been pushed since the 60's, my radiator guy probably recycles about 2000 radiators a year.
  • mroberts5
    One last bump to the top for ideas before I scrap it
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    What are the dimensions? Do you have a picture?
  • Canucker
    That's a good idea @Hap_Hazzard I'd like to see some pictures. I've been known to drive a long way for unique radiators
  • Hap_Hazzard
    edited November 2019
    I wouldn't even have to drive that far, but I need to know if I can use it.
  • mroberts5
    I'll get it up tomorrow
  • Hap_Hazzard
    Great. What about the radiator? ;):D
    FredCanuckerttekushan_3
  • mroberts5
    .....yeah, I read that twice as I typed it...hit post anyway. B)
    ttekushan_3
  • mroberts5
    105w x 24h x 3.25d.
    8 "sections"
  • Hap_Hazzard
    I'm afraid that's too tall for my purposes. :(
  • Hap_Hazzard
    If anybody is looking for a condensate radiator for a basement or garage, this would be great for that.
  • Dave in QCA
    Dave in QCA Member Posts: 1,803
    Who do you use for radiators? Just curious. I've been searching for a particular radiator for several years.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    JC Radiators 1773 407-7115
    Dave in QCA
  • TAG
    I assume that's designed for steam ?
    That's the type I remember in the garage of my grandparents -- what do you think the output w/ hot water ?
    Is it all one long section ?
  • mroberts5
    Here is a pdf that shows some more detail. https://heatinghelp.com/assets/documents/Pierce-Butler.pdf
    I can take photos of any detail you're interested in.
    The assembly seems to be put together as two halves, each w/ press nipples and then the halves with left/right nipples.
    I have the brackets as well. I can probably help load into a truck.
  • Hap_Hazzard
    Thanks for posting that PDF. I couldn't find these radiators in my EDR book, so I printed the pages and added them.
  • mroberts5
    It came from this site :)
