Water beading out of overhead steam radiator valve
mike212
Member Posts: 51
I have an overhead steam radiator (one pipe) in my garage that has a very slow drip of about 5 drops each time then boiler fills the radiators with steam. Since I have steam (not hot water) this seems like it could be the sign of something wrong with the overhead radiator - there should NOT be enough water build up to cause a drip in a steam system, right?
Should I just give the nut on the valve a slight turn to tighten it further or am I just masking a bigger issue?
If that doesn't work you may need to repack the nut as the gasket may have disintegrated.
Order this, https://www.amazon.com/gp/product/B002QEUSMS/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
Loosen the nut and lift it up, wrap the rope three times around the spindle cut to size, tighten the nut and you should be good to go, you just made a new gasket. Check for leaks by wrapping toilet paper around the spindle. If it is dry through a heating cycle you are good to go.1
