New Yorker CLW-3
Where can I find parts for my New Yorker boiler model# CLW-3. The blank plate that is covering the area where the tankless hot water coil would go, is leaking. I need to replace the plate and gasket.
  • STEVEusaPA
    The plate shouldn't be leaking, but the gasket could. Did you try New Yorker's website or call their tech support?
    EBEBRATT-Ed Member Posts: 20,084
    part #645751 Torrco supply about $45 you can find them on line
