New Yorker CLW-3
Wildwilly49
Member Posts: 1
in Oil Heating
Where can I find parts for my New Yorker boiler model# CLW-3. The blank plate that is covering the area where the tankless hot water coil would go, is leaking. I need to replace the plate and gasket.
The plate shouldn't be leaking, but the gasket could. Did you try New Yorker's website or call their tech support?
part #645751 Torrco supply about $45 you can find them on line0
