water discharging for overflow
I have a Viessmann Atola EC-115 that is discharging about 2 pails of water a day through the overflow pipe (live in Toronto Canada). Is there anything I can do or do I call a pro?
    Jamie Hall Member Posts: 26,838
    I presume by overflow you are referring to the pressure/temperature relief valve? Because, unless you live in a tall building, the pressure showing on your gauge seems high. So... check the expansion tank for correct charge, or functioning at all, and if there is an automatic refill, check that.
  • neilc
    neilc Member Posts: 3,116
    and are you making domestic hot water with it ?
    known to beat dead horses
