Hydrostat3250Plus position of jp2 jumper.
inthewind
inthewind Member Posts: 2
What is default position of Jumper on JP2 on the circuit board?Across first two pins or second two pins.
    EdTheHeaterMan Member Posts: 12,034
    This is just a guess, but from several pictures of this control fornd on the inter-web, and the world wide net, it appears to be the first two. The pin closest to the digital display and the center pin
