Taco 007 circulator not working
razzor
Member Posts: 20
I have a zone in my hot water baseboard system that doesn’t heat up. The circulator pump didn’t seem to be working so I replaced it. Still no heat to that zone. The Taco SR503 Switch Relay light for that zone comes on when thermostat is calling for heat but don’t hear the circulator pump running. Thoughts or ideas?
Thanks
Thanks
A multimeter to check that you have ~120 volts to the circ would be a good start. I found this app the other day but have not had a chance to use it. https://www.danfoss.com/en-us/service-and-support/downloads/dcs/magnetic-tool/#tab-overview
It should verify rotation.
If you have power and rotation, you must be air locked."If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Thanks Zman. So the thermostat is working since the zone light comes on. I thought maybe the circulator was bad so replaced it. Still not working. Worked fine up until it didn’t! Not sure what would cause power not to get to circulator.0
the relay could be bad or bad wiring or connections. have to trace it back with a meter0
The zone light tells you the relay has power to the coil but nothing else. You'll still need to verify you've got power to the pump terminals.razzor said:So the thermostat is working since the zone light comes on.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
