Removing Cap on Heating Oil Tank (To Install Gauge)
mike212
Member Posts: 51
I'd like to install a wifi connected gauge in my oil tank. There are two spots, one where there is a traditional gauge already which I'd prefer to leave as is and the other spot which is available and has a large square nut attached to a cap that seems like its should unscrew given enough force but I can't get it to budge.
I'm using a straight pipe wrench which grabs the nut perfectly, but I can't get it to move. I'm thinking I should pick up a pipe tomorrow that I can slip on to the wrench handle to get more leverage, but before I over force it, should I 1) try using WD40 or some other solvent to loosen the cap? or 2) try peeling back the coating around the cap, maybe that is gripping it shut?
What tool are you using? A 2 ft pipe wrench? Good. 14" pump pliers? Not so good.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 48 Industry Classes
