Brand new boiler- water tube has gunk in it
seaamygo
Member Posts: 19
I just had my brand new peerless boiler installed two weeks ago. It’s been cold enough here in Connecticut for it to fire up every day since then. It’s been working well but when I went down to the basement to put away some Halloween decorations I was looking at it & noticed that the glass tube which Shows me the water level was going up and down (always below the level line sticker) and the tube has brown gunk in it. The boiler was running while I was looking at it. Should the water in the tube be clear?
The one photo that has the yellow arrow shows where the water level was when I took that picture
Not surprising. A new boiler installation will almost always loosen lots of gunk. Call your installer back to flush it out.
You may need to have this done more than once.All Steamed Up, Inc.
Consulting1 -
seaamygo,
I have the same issue plus some.0 -
Question, did they skim the boiler after installation to remove cutting oils?DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Some installers like to let the boiler run for a week or two to make sure all the crap is loose, sometimes the take away the old boiler at the same time. Call the installer and ask when he's coming back to skim.
Don't be amazed if his answer is why. Some installers don't include the cost of skimming in the quote even though boiler manufacturers all view it as part of the installation. It's an easy operation as long as they installed a skim port, if they didn't install the skim port tell him you want it installed. There are several good skimming tutorials here jut search for them.
3PSI gauge1
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
