Heat pumps and radiant heat
Just had heat pumps installed. We have radiant heat typically. Going on snowbird trip (6 weeks to 3 months). We typically turn radiant heat to 65. What should we do with pumps. Turn off? Need info ASAP. TIA
  • Zman
    Zman Member Posts: 7,609
    Is it an air to air heat pump separate from the radiant or is it air to water?
    Albert Einstein
    HVACNUT Member Posts: 7,446
    What climate are you in? A 2 stage heat thermostat to back up the primary heat source should have been installed. If there's an electric heat element in the heat pump you'll need a 3 stage heat thermostat. Depending on your region, neither radiant nor heat pump might be sufficient to maintain temp on a design day. I would get a good WiFi thermostat so you can monitor the temperature while your away.
