Radiant system losing pressure
hello everyone, looks like a great site, glad I found it.
So I have an in the floor thin slab radiant system I installed about 25 years ago when I built the house, and it has been generally a great system functionally and quite reliable (less a couple of pumps and zone valve motor failures).
last spring after I shut the system down for the season, I decided to close the domestic water supply valve and watch the pressure gauge in the system and to my amazement after about a week it went from 10 to 0 psi. so I opened the valve again and pressurized the system then repeated the test with same results. I left the supply valve closed all summer long.
so the question is where did the water go?
I have access to visually inspecting a lot of the copper supply piping, and where I don't (like between first and second floors) I see no evidence of leaking down to the lower story. I have also visually inspected all of the zone valves and tubing manifolds, all dry as a bone.
To be honest after I did the test in the spring and the subsequent visual inspection I basically forgot about the problem all summer long, please don't ask me why..
This fall when I started the system and opened the water supply valve I could hear air rushing out of the air separator for about 10 seconds or so, and since this is a 1 1/2 inch main circulation loop that sounds like a fair amount of water missing in the system to me...
I know I have not given a lot of system details, but I thought I would just pose the question and let people ask what might be relevant.
Thanks in advance, James
  • Zman
    Zman Member Posts: 7,609
    Some systems just leak very slightly. The big concern is that the fresh water added is oxygenated and will cause corrosion. I would try to quantify the leak. Does it take a whole week to drop? Are you just adding <1 gallon?
    You can put the system under high pressure to try to find it if it is an issue. Little leaks like that can be very hard to find.
    Albert Einstein
  • WarmJames
    WarmJames Member Posts: 21
    Thanks Zman,
    Yes it takes the full week to drop to 0, maybe a little longer and I would say I am adding less than 1 gal to bring back to 10psi. Since the added water is from the utility I would say it is oxygenated, but isnt that the function of the air seperator to remove any gas?
  • Zman
    It is hard to explain but the oxygen is entrained in the water and is only depleted when it oxidizes something. This can corrode ferrous components in your system. I don't think I would be too excited if I was losing such a small amount, although it would be nice to know where it is going.
    Albert Einstein
  • WarmJames
    yes I agree been nice to know where it's going..
    I did some other reading and one post suggested taking a water sample from the Why strainer and see if there are any black bits in there to see if they're attracted to a magnet telling you that it's corrosion. I did this and there were a few very small black bits but not magnetic, so I assume hose or gasket fragments. I also checked the water pH and it looks like it's sitting at about 6.8. The only ferrous metal in the system is the boiler jacket itself.
  • GroundUp
    GroundUp Member Posts: 2,513
    6.8 is very low, likely due to your excessive makeup water, and will speed up the corrosion process. This is subjective, but I like to keep pH in the 8.5-9 neighborhood. How many loops is the slab system and does each loop have its own isolation valves? For the system to be losing anywhere near 1 gallon of water over the summer, you have a fairly substantial leak and if it were above the floor I'm fairly certain you'd have noticed. If it were mine, I'd be isolating 1 loop at a time and keeping the makeup water closed while letting the system run. If you check it every day, you'd notice a drop in pressure or lack thereof and should be able to locate the problem loop.
