Do you hammer nails up to floor or angle grind nails so they no longer exist?
SeanBeans
Member Posts: 525
Angle grindermulti tool works great0
Why is no one picking the hammer method?
Someone please enlighten us0 -
Grind flush. Sometimes I hammer them flush.
If I come across a few stubborn ring nails I just swear at them. That usually works.0 -
Angle grinderWith regard to the hammer method here are some issues I could see coming up:
1. Artwork falls off walls in living room while your hammering.
2. Cut nail ends up being pushed through hardwood floor, splits rare super expensive African Burkea species.
3. Nail pops through underlayment and pops a hole in the vinyl flooring that great grandpa installed (as a wedding gift) days before he died.
4. Sheetrock or plaster walls develop "nail pops" after your done hammering for a few days.
5. Nails that you pound magically end up between the hardwood floor and the sub-floor, now the customer hears a squeak every time they (or the dog) walks in that area of the floor.
6. A few ceramic tiles in bathroom and kitchen crack and/or grout cracks.
Yes, I am exaggerating but I could see any of these scenarios coming up.4 -
Angle grinderIf you push the nail up, where does it go? It could come to the surface only to be pushed or driven down at a later date. With hardwood, the floor will lift and creak. Unless you can go above and pull the nail, cut them off."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Thanks guys!0
We used and angle grinder and the eventually switched to the multi tool.
No hammering here, sir.0 -
of all the tools I have tried an air powered die grinder with a thin cutoff wheel works best. Super high rpm, it doesn't get hot to hold, cuts the least amount of metal. And your arms are in a more comfortable position compared to an angle grinder where you need to reach into the joist bay.i
Hammering them usually ends up pushing the up a bit. If they are hardwood "cleats" this T shaped nail, it will split the upper part of the groove sometimes.
I've found grinding is as quick as hammering and less risk of damage.
Ear plugs, face shield, gloves, respirator.Bob "hot rod" Rohr
Living the hydronic dream0
- 120 Geothermal
- 169 Indoor-Air Quality
