Can one pipe steam systems be zoned
dopey27177
Member Posts: 887
I recently was asked if one pipe steam systems can be zoned.
In my time as a consultant I was hired to make one pipe zoned systems to work properly.
Here the discussion revolves around poorly designed and proper installation.
The drawings and discussion are taken from my book Steam the Perfect Fluid and some of the Problems.
The book is available in Dan's library, Barnes and Noble,Amazon & Dorrance Publishing Pittsburgh, Pa
Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron
Buy this book.dopey27177 said:The drawings and discussion are taken from my book Steam the Perfect Fluid and some of the Problems.
The book is available in Dan's library, Barnes and Noble,Amazon & Dorrance Publishing Pittsburgh, PaAll Steamed Up, Inc.
Consulting1 -
I would second that ,I ll attest to that having spoken to mr Byron many many years ago about a giant old home and his knowledge of this stuff is all consuming and span many years ,he like Mr H is a true treasure of lost knowledge .i would gather anything he has written is loaded w little known facts that make our jobs easier and is a look back at history which is some times all you have to go with when looking at old stuff aside from number one rule hi goes to low weather temp or pressure lol but I would gather there’s a lot more then that in anything Jacob has written also he is one hell of a nice gentleman .it s awesome that your posting peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Thanks steam head & clammy
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
Here is the link in the HH store. I assume buying it with this link helps HH with some linking revenue so that's where I'm going to buy it: https://heatinghelp.com/store/detail/steam-the-perfect-fluid-for-heating-and-some-of-the-problems
Plus as of this writing, it's about 1/3 off regular priceNJ Steam Homeowner. See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
