Flame adjustment and control
jaygerond
Member Posts: 2
in Oil Heating
I have an Aero gun mounted on a New Yorker oil burner. I recently had smoke coming out of the burner. Took apart and vacuumed out the entire burner (lots of soot) and changed nozzle. The fire box is cracked in several places so a new burner is on the horizon. Put back together and adjusted air so I i have a nice bright yellow flame. Obviously, you don't want a dark yellow flame as this will promote soot build up. My question, when running the flame has the appropriate bright yellow flame but when the burner shuts down the flame goes to dark yellow color for two seconds or so before shutting down?
Why is this happening and what are the possible solutions?0
Sounds like you need to call your HVAC guy asap. Nothing you described sounds good. Turn the boiler off until they arrive.jaygerond said:I have an Aero gun mounted on a New Yorker oil burner. I recently had smoke coming out of the burner. Took apart and vacuumed out the entire burner (lots of soot) and changed nozzle. The fire box is cracked in several places so a new burner is on the horizon. Put back together and adjusted air so I i have a nice bright yellow flame. Obviously, you don't want a dark yellow flame as this will promote soot build up. My question, when running the flame has the appropriate bright yellow flame but when the burner shuts down the flame goes to dark yellow color for two seconds or so before shutting down?
Your burner needs a combustion check with instruments0
You can't adjust an oil burner by eye...never.
