Dirty site glass
I know there has been much debate on draining in the spring. I drained the boiler from the blow down valve and also hardford loop and refilled. The water bounce is gone and the water is not running down from the top of the site glass.0
Did you put any chemical additives in the boiler when you filled it? My guess is cleaning it with a brillo pad has scratched the interior walls of the glass and that surface now is susceptible to staining. Try a new sight glass.0
Thanks Fred...I couldn’t think of any way to get it clean. No additives0
Do not be discouraged is all experience. I hope the new glass lasts much longer.0
I tried rolled up paper towel and cotton balls first. It was baked on after just 2 days. I thought about using oven cleaner.0
If you add a sight glass blow down that will give you the ability to steam clean the sight glass. I haven't taken mine out since installation in 2014 and it's crystal clear.
I also run water treatment which, IMHO, makes a huge difference in water quality.
I would agree with others saying don't drain the boiler, I actually overfill mine to the riser pipes and close my king valves for summer lay up. The idea is to limit the oxygen exposure, remember water doesn't corrode, oxygen in the water corrodes. With no water you surely have plenty of oxygen.0 -
Good advice..thanks0
I like this procedure. Do you also boil the water once after overfilling it, @KC_Jones ?KC_Jones said:I actually overfill mine to the riser pipes and close my king valves for summer lay up. The idea is to limit the oxygen exposure, remember water doesn't corrode, oxygen in the water corrodes. With no water you surely have plenty of oxygen.
I fill it while it's firing, so get it up to steam, start filling, then when I'm satisfied I shut it down, cool, then close the king valves. I figure closing the king valves does the most as it eliminates any exposure of fresh oxygen to the actual boiler.ethicalpaul said:
It's all theoretical, but it makes me feel good.1 -
Cool, I like it, but one more bit of clarity, do you boil the fresh water at all, or do you stop the fire when you start filling? (I ask because of item #1 below)
I would copy your procedure, but with these changes:
- I would make sure to boil the fresh water even a little (unless I've been reading things on this site wrong about unboiled water)
- I would leave the king valves open for a day or so before I closed them (not sure this matters)
- I would add enough steam master or 8-way to get the overall ph level of all the water up to 10 or 11NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el1
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
