Pipe Insulation
rhw1
rhw1 Member Posts: 32
Got all the stuff to insulate but need some direction on insulating the new near boiler piping with all it's twists and turns. Not real good with puzzles so I am wondering if there is a video somewhere in the archives or on line that I can follow. Thanks.
  • Zman
    Zman Member Posts: 7,611
    These guys do a pretty good one. https://www.youtube.com/watch?v=H1X5QBudVO4
    Basically, you do all the straight sections, holding back from the corners the appropriate amount then go back and fit corners a Tees
    Albert Einstein
  • rhw1
    thanks. are there others?
  • gfrbrookline
    gfrbrookline Member Posts: 776
    This video is the best one, take your time, buy 1" thick insulation and the corresponding corners and T's, I find the tack to be really helpful and make the corner easy, just be patient. I also really like the knife they sell to cut the insulation, make the cutting easier.
