Pipe Insulation
rhw1
Member Posts: 32
Got all the stuff to insulate but need some direction on insulating the new near boiler piping with all it's twists and turns. Not real good with puzzles so I am wondering if there is a video somewhere in the archives or on line that I can follow. Thanks.
These guys do a pretty good one.
https://www.youtube.com/watch?v=H1X5QBudVO4
Basically, you do all the straight sections, holding back from the corners the appropriate amount then go back and fit corners a Tees"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
thanks. are there others?0
This video is the best one, take your time, buy 1" thick insulation and the corresponding corners and T's, I find the tack to be really helpful and make the corner easy, just be patient. I also really like the knife they sell to cut the insulation, make the cutting easier.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
