Gas valve
galcovef
galcovef Member Posts: 2
I have a 36e86 gas valve that needs to be changed out yet they don’t make it anymore can someone was me in the right direction on what else would work
Thanks
    HVACNUT Member Posts: 7,439
    I found the 36C84-912. It says it must be hardwired as the harness is no longer available.
  • unclejohn
    unclejohn Member Posts: 1,833
    You need a new furnace. Mercury flame sensor.. come on.
  • galcovef
    Really?
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    What is wrong with the valve? Has the pilot been cleaned? Is the mercury sensor getting hot enough to walk over and make the other side of the SPDT switching? My experience (over 50 years) with these systems is it is usually just a dirty pilot, or a bad mercury sensor.
    DZoro
