Rinnai heater not turning on
kcclark66204
Member Posts: 1
I use a Rinnai heater for both DHW and floor heating in an 800 Sq ft cottage. Has worked great for 7 years, but now when the thermostat calls for heat, the circulating pump comes on, but the heater does not come. Still working fine for DHW. Any suggestions?
It still fires up OK for domestic hot water? Then it's not really the Rinnai, but a problem with the command from the thermostat to the circulator to the boiler.Br. Jamie, osb
