ISO Baseboard ratings.
Harvey Ramer
Member Posts: 2,281
I am doing a job that has some baseboard that i need to find ratings for. I couldn't find the manufacturer. The elements measure 2" deep by 5-1/2" tall. They contain 2 3/4" inch pipes, which are plumbed in parallel.
Anyone have any ideas?
That sounds like Smith’s Heating Edge.
https://smithsep.com/wp-content/uploads/Heating-Edge-2-Literature-2.pdfBob Boan
Look at Beacon-Morris and Slant/Fin as well.
Can you post some pics?All Steamed Up, Inc.
Consulting0 -
If I can't identify I just measure and look for a close match. The ratings will be close enough.0
It is similar but the coil block is smaller and the cover looks like conventional basebaord.Ironman said:That sounds like Smith’s Heating Edge.
https://smithsep.com/wp-content/uploads/Heating-Edge-2-Literature-2.pdf0 -
I already looked into slant fin. I didn't know beacon and morris made baseboard, but i will check them out.Steamhead said:Look at Beacon-Morris and Slant/Fin as well.
I wish I had photos.0 -
I am considering try to extrapolate the ratings from smith's environmental.EBEBRATT-Ed said:If I can't identify I just measure and look for a close match. The ratings will be close enough.
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
