Lawler 805 Thermostatic Mixing Valve
BillMcBee
Member Posts: 1
I have started to get a high pitched whine coming from the mixing valve. It is operating properly for now. Could the springs be going bad and allowing water to bleed through causing the whine? If not should I just rebuild the whole valve? Any thoughts or comments are welcome. Thanks
