Steam Re-Pipe
Dan Foley
Member Posts: 1,268
Brian and Dragon re-piped this two-pipe Vapor System in Chevy Chase, MD today.
Typical complaints; water hammer, uneven heat, high gas bills.
Before pics
Before pics
Re-piped with two risers to a properly sized header.0
The homeowner asked me why his pipes freeze every year. Here’s why. The water heater is outside! You cannot make this up.0
Wow!Never stop learning.0
We removed this and installed a standard 50 gal. Bradford-White tank style water heater in the boiler room. Problem solved. Sometimes the simplest solution is the best solution.0
Makes you wonder what their thought process was as they were installing a tankless outside on the side of the house.Never stop learning.0
Genius has its limitations.
Idiocy knows no such boundaries.0 -
In other words, you can't fix stupid!Dan Foley said:Genius has its limitations.
Nice work, Dan.All Steamed Up, Inc.
Consulting1 -
Nice work you and your guys did Dan.2
The outdoor heater cracked me up - in Maryland? I've seen a picture somewhere of a tankless that had been in service for something like then years with no problems. Location? Exposed on a rooftop in San Francisco!0
- 120 Geothermal
