Why your boiler needs a low-water cutoff
HeatingHelp
Administrator Posts: 707
The contractors involved in those two jobs now install low-water cutoffs on every boiler they install, as should every contractor.
You should have two low water cut offs. The mechanical ones get stuck if not maintained properly.0
As well as a low pressure cut off.
But for wood boilers a LWCO can make things worse for a runaway boiler with little control of the fire.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
On that first job, did he also repair the leaky radiant pipes? Because if not, he's probably going to be back there at some point in the not too distant future,0
Hi..My Boilers were fairly recent having been put in by a member here 3 years before this happened (4 years ago) ..but the Cycle-Gard on one started calling for water not registering that the Boiler was full of water.
I was laying in bed about to dose off at 1:00 or 1:20 AM and I hear water running..then stop..then I heard it again a few minutes later and not stop..I got out of bed looked around went to basement and saw Water Feeding into the Boiler..but sight glass full and some water on the floor. I stopped water feeding into the Boiler and stopped Boilers.
What to do ..Winter ..I emptied Boilers to proper water level..kept water into Boiler off and ran it and kept my eye on it every day or two..for the next 4 years : (
Since a bit after that I have lost half my hearing in one ear if it was today, Id never have heard it.
Anyway..The manufacturer said Clean the probe..finally at end of last year I called PSE&G "Worry Free" and guy came over and changed Probe in Cycle Gard..on the faulty one..Should I get them in to do the other one to?
Anyway There must be a better way..when water gets too low Boiler should just shut down period..its better than risking a Low Water Cut Off not stopping the call for water and causing a disaster. ..Or there should be a less electronic more fault proof high water cut off.0 -
Cycle Gard..is not a Low Water Cut off ?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 988 Plumbing
- 389 Solar
