Need to speak with someone with some experience with water flow balancing/commissioning.
JohnNY
Member Posts: 3,413
I've got several circuit setters and my testing equipment but I'm not comfortable with my findings on a particular job.
I could use some help from a commissioning tech or similar. The differential Delta-P meter I'm using is a Mid-West Instruments model 820.
Thank you.
Thank you.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Classes
what type of balance valve? With a variable office type you need a table to set or confine the flow from the readings
Idronics 8 I think it was goes into the art of balancingBob "hot rod" Rohr
It's a house full of Taco Accu-Flo circuit setters.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
