Baltimore, MD School Boiler Room Explosion
Mike_Sheppard
Member Posts: 696
Sounds like delayed ignition to me. Unless one of the "outside contractors" did something .....like with a torch. Does not say if the boilers were operating...think they must have been if the stack went down0
@EBEBRATT-Ed from what I’ve heard the contractor was in the middle of performing a start-up on a new burner on a watertube boiler. Not confirmed though.
Contractor is a competitor of the last company I worked at, and is the company I took all the work from when I moved to my current company. (Current Company subcontracted their boiler work to the company responsible for this explosion).Never stop learning.0 -
@Mike_Sheppard , me thinks someone wasn't paying attention. Lucky no ne was seriously hurt. You can't take anything for granted in this business.0
I sure would like to see pictures of the boiler, burner and the boiler room. Most likely a gas, propane or fuel oil explosion. A catastrophic pressure vessel explosion would have caused much more damage to the building.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
