What do they mean by this??!!
Hoping for some feedback from heating experts here. If you saw the line "Find two capped off supply and return risers in the wall, connect them" on a proposal to evaluate the heating system in a 5 story loft building, what would you interpret that to mean?
  • STEVEusaPA
    A...what did they say it meant?
    B. I'd guess somewhere someone removed 2 radiators (supply & return) and capped them off.
    So someone has to find them, and the radiators and reconnect them.
  • ratio
    ratio Member Posts: 4,168
    Agree with @STEVEusaPA. It means they're not proposing to run new risers from the basement\wherever, just find & attach to (hopefully!) existing pipe that's hidden in a wall.
  • kdshakk
    kdshakk Member Posts: 19
    Thanks for your replies. What the initiator of this action "says" it means is that the plumber will cut the risers. What he did was have the plumbers cut the supply and return risers because he did not like the way they looked. Now he is saying that because the work order was signed we knew that was going to happen. Just trying to see if that is the interpretation.
  • Fred
    Fred Member Posts: 8,542
    ????? If you cut supply and return lines because you don't like the way they look AND you don't find a way to relocate and reconnect them, what did you expect? They weren't in their original location for looks. They served a purpose; to supply and return steam or water.
    kdshakk
  • kdshakk
    You are absolutely correct. He knew what he was doing, but figured the rest of us would not be able to figure out his "code", which was correct. The ensuing problems have been huge, but know we are down to disputing what the original intent was and I want an expert interpretation of what that line in the proposal meant.
  • ratio
    Sounds like this is going to litigation/arbitration? An internet opinion isn't going to help much with that I think. You probably want an expert opinion. I believe some here have done that in the past—they may be able to offer a more useful opinion.
  • KC_Jones
    KC_Jones Member Posts: 5,894
    It reads to me like he intends to uncap those pipes and connect them...to each other. There is no mention of radiation at all.
    2014 Weil Mclain EG-40
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,681
    If it’s a loft building, it’s most likely two-pipe steam. Connecting a supply to a return without benefit of a steam trap or orifice would certainly screw things up for the rest of the tenants.
    Retired and loving it.
    STEVEusaPA
  • GroundUp
    GroundUp Member Posts: 2,444
    It would mean to me, that I need to call the PM or engineer and ask what they mean.
  • kdshakk
    I appreciate how this community always fires in with their thoughts. We are indeed probably about to enter into litigation, BUT it is not with the plumber involved. I live in a small, coop, loft building and one particular tenant decided to direct the plumbers to cut those pipes and THEN said that the line in the work order "Find two capped off supply and return risers in the wall, connect them" was indicative of this intention. I wanted to get some feedback without initially stacking the deck. I agree that we will need an expert to provide an affidavit.
  • Intplm.
    Intplm. Member Posts: 2,798
    Shouldn't have to read into this all that much.
    Find the lines and reconnect the return to the return and the supply to the supply.
    Hopefully that will be the end of it.
    Cooperation from all is , of course "key" here.
    I hope things get resolved soon.
  • STEVEusaPA
    I think @DanHolohan nailed it best.
  • ChicagoCooperator
    ChicagoCooperator Member Posts: 363
    And don't forget to change your building rules to not allow modifications to the heating system without proper professional oversight. ...
  • kdshakk
    @ChicagoCooperator, we actually already have such rules. They were ignored.
  • ChicagoCooperator
    Fun! Sorry you have to deal with that.
